October 24, 20223 yr 4 hours ago, larry s. k. said: Hi , , can you all post pictures of , metralla 23 ,Tony’d and Dino , montadero 51 , ,, there both rare bikes ,, very collectible , Larry from states Larry, if you do a Google search for "Bultaco model 23 images" you will find lots of photos of model 23 Metrallas
October 24, 20223 yr 15 hours ago, feetupfun said: Larry, if you do a Google search for "Bultaco model 23 images" you will find lots of photos of model 23 Metrallas Hi feetupfun , ya thanks reply , you never know what old bultaco could look like ,,, hear a pic of my 121 project in the making , 2 winter , , of a basket case , looks a little different from original , it’s a replica, with matching numbers , takes time , find parts getting closer all the time , cheers ,, Larry
October 30, 20223 yr Hi you all , bultaco fans I would like to see PICTURES , all models ,, you have excluding projects , cheers larry
October 15, 20232 yr Hi not sure if this thread is still alive. I have a 1973 bultaco pursang. And apparently has had a 1971 engine put in but can't find the size anywhere when putting in the engine number. It's m-500977c. Any ideas? cheers
November 11, 20241 yr Hello, the number stamped on the engine of my Bultaco is 'JM-11602620'. I am trying to figure out if this is a 326 or 348 cc?
November 12, 20241 yr The only 326cc Alpina is the model 99. All the later "350" Alpinas were 348cc. Model 116 is the next "350" Alpina model after the model 99.
