May 15, 201313 yr Im after one. I do have some posh hub (apparently Talon????) but I just want the original wheel and hub to be honest. Anyone know where I can get one and if any other TY wheels fit? Cheers in advance
May 15, 201313 yr Hi Rob You would be better having a new wheel made up around your Talon hub. The standard mono rear wheel uses Z spokes which are becoming increasingly harder and more expensive to find. Most second hand mono wheels have some degree of rim corrosion and you will probably end up having to rebuild anyway. Edited May 15, 201313 yr by dougalthedog
May 15, 201313 yr Author stop bothering the nice trials folks Rob You still hanging around public toilets Danny? Good point Dougal. Just got to confirm this hub is Talon then I can set about sorting what rims match etc. Cheers.
May 16, 201313 yr Sorry to hijack the topic but is it possible to lace a tubeless rim onto a TY mono hub? Do the Z shaped spokes cause any problems doing this? Thanks.
