5K Ohms Resistor Plug Cap ?
trialsrfun
When I built the bike the system came without a plug cap so I used a NGK hard plastic type without a resistor but I was now thinking of fitting a rubber type bit more P65ish so wondered if my earlier choice or no resistor was correct.
Don't combine a resistor cap with internal resistor plugs. This doubles the resistance and may give problems especially with starting.
Plugs with resistors usually have a prominent 'R' in the manufacturers code.
