Does Bosi Exhaust Fit 2013 Evo?
hasselferrit87
Because the 2013 hydro frame is different! So wasnt sure wether ut came out further hence denting the front pipe closest to frame! The ? Symbol clearly shows that its a question because i wasnt sure, i wasnt stating myself wether this has to be done!
I had the same problem with my front pipe, It fit the 2010 bike fine, But the 2011 bike, The motor was mounted further foward, So I had to dent the back of the pipe slightly and swap the bolt to a countersunk one, Bosi eventually brought out a new one to fit, Which I have just swapped mine to recently, Didn't know the new one wouldn't fit the 2013 bike.
Thanks ben! im asking these questions because wheb you look at them they state 2009-2012 so was after some advice wether tbey can be adapted! The one im buying is second hand so how would i know if it was the newer model? Pipe i mean not bike
Hi,
First pic is the old shape pipe, If you look at the top bend you can see it is different to the new one, This is so it clears the engine mounting, Although it is very close to the small screw that holds the tank panel on my bike, Not sure what it's like on the 2013 bike.
When I swapped mine to the newer bend I did find that it increased performance slightly on the bottom end.
Edited by benbeta23
You can make it fit by putting a dent in the back and use a countersunk bolt instead, It may fit the 2013 differently, I'm not sure, But you are probably best comparing it up to the bike when you get it to see what you need to modify.
