September 9, 201312 yr Hi, I had to fix the clutch to my Beta and somehow a lost the steel ball that is between those two rods. The ball is 6 mm diameter and its code is: 2890210 000 BALL D6. I know, its price it's very low but it will take about 2 weeks to get it if I'll order it. Does someone know what bearing I can break and get a 6 mm steel ball? I need the code of the bearing or any other idea. Regards,
September 9, 201312 yr Most bearing shops and bicycle shops sell individual balls. You know it is 6 mm so just call around and you should find one.
September 9, 201312 yr Author I asked in one bicycle shop and they have 5.5 and 6.3 mm only. I sent an email to a bearing shop and have no answer yet. That's why I asked here, maybe someone knows the code of a bearing with 6 mm balls. I will try a bicycle service. Thanks.
