October 21, 201313 yr Author You reach those by removing the skid plate? Yes.Unbolt the bashplate and they are easy to pull down for cleaning.I should have taken an "after" pic.It looks like new.
October 21, 201313 yr Good job ric, a good result and good tip for others to remember going forward. This is one area of maintenance I would not normally consider "regular" but will from now on
November 1, 201313 yr Author Booo.Right back where i started.It ran great for an afternoon,but won't start again.Maybe time to take it to Brantford.
November 1, 201313 yr Hi Ric possible fuel pump is defective, they can be intermittent, when you apply a 12 volt battery does the fuel pump make a hi pitch whine. If it's a a slower low pitch sound that might be the clue. I suggest you take your bike to Rob Langs Off Road in Dorchester as your bike is out of warranty. He will sort your bike out for sure. He is our Sherco Canada tech and parts manager and I trained him on the Ossa unique build. He has the Ossa map and diagnostic tool also. cheers
November 18, 201313 yr Author I'm ashamed to admit that i took it to Lang's Offroad on saturday.I'll let you know the outcome.
November 23, 201313 yr Author It's fixed! Rob Lang called and told me that he found a lot of metal debris (no idea where it came from) stuck to the inside of the flywheel.It was disrupting the ignition pickup and.Hence,no spark.
November 24, 201313 yr It's fixed! Rob Lang called and told me that he found a lot of metal debris (no idea where it came from) stuck to the inside of the flywheel.It was disrupting the ignition pickup and.Hence,no spark. Ahh. that's probably the heads of the bolts which hold the stator in place. I had one break off so replaced them all with countersunk allen screws.
November 30, 201312 yr Author Picked up the bike today.Starts 2nd or 3rd kick from cold (-5c) and first kick when warm.There was a chunk of metal from the head of a stator bolt (they were all tight) that was moving around inside the flywheel.When it stuck near the pickup...no spark.Good reason to blue loctite the stator bolts once a year. Edited November 30, 201312 yr by ric h
