October 15, 201313 yr Hello, i have a TY175 that needs electronic ignition as the points need changing and i thought it best to do it once. Any suggestions or recommendations out there? thanks
October 15, 201313 yr I've witnessed the John Cane type (on one of my TY175s) and the Electrix type (on a friend's TY175) and they both work well. The only negative I have seen is that the Electrix one uses a very long HT lead because the HT coil is located down beside the airbox
October 15, 201313 yr My recommendation? Stick with the points. I purchased a TY and the ignition was troublesome due to breakdown of the LT coil. I got it rewound in modern material and a couple of other tidy up jobs for £60 all in so I now have an absolutely reliable system that can be tweaked should the need ever arise. I've seen too many twinshock TYs with deceased electronic ignition (four in one event) to want to take a £200 gamble - it can be a long push. The standard system was very well regarded in its day and is no less good now if any problems of ageing are sorted out. Edited October 15, 201313 yr by 2stroke4stroke
October 15, 201313 yr Hi I built my TY up from a basket case and ran points for a year but it seemed to lack that instant power so I invested my £199.00 at TY Trials (John Cane) and it was the best money I spent . This was 5 years ago and the bike has not missed a beat and it pulls like a different bike now. John Cane has upgraded his ignition now as I have the early one but it is easy to fit and works great. I know that if it goes its another £200 but that is just sods law. It all depends how much you ride the bike to get your moneys worth I ride mine as much as I can and I have had my fun.
October 15, 201313 yr Fair enough - mine's a 200 and has too much instant power - wish I knew what had been done to it.
October 15, 201313 yr I thought about the 200 option but didn't have a spare barrel and someone recommended the ignition so thought I would try it
October 15, 201313 yr Quality aside (and I have no experience of either system mentioned) ask the suppliers for an ignition advance curve graph. Some ignitions have no advance and will give soft / less power. Some have quite a few degrees advance just over tickover and will give much more torque in this RMP range than fixed timing. Some have retarded timing at very low RPM which makes stalling and kickback on starting less likely
October 15, 201313 yr totally agree about the benefits of having an advance curve. That's why I put the ignition on my TY175. It is a 205cc engine and I wanted to make it harder to stall, and also retain top end power
October 28, 201313 yr Another thumbs up for TY trials electric ignition from me. Replaced mine last year, simple to fit, makes it very difficult to stall, and has been trouble free from day one. Mark
October 31, 201313 yr When installing an ignition with an advance curve do you start from the standard advance and just get additional advance, or start from an initial position retarded from standard?
November 1, 201313 yr whatever you want. Fixed points timing is set as a compromise for low and high rev operation. If you want to set you electronic ignition for the smoothest and most reliable response at low revs, set the timing to be a bit later than standard fixed setting at low RPM. If you want to maximise top end power, set the timing with the low RPM setting at the standard fixed setting. It really is something you should play around with until you are happy with how your motor runs for the way you like it.
