October 28, 201313 yr Crazy question. I have a small bit of play in the rear wheel bearings, very slight when I move the wheel side to side, but I can still feel it...is this normal? Can it still be ridden a few more time if it needs to be replaced? Will it do any damage to the wheel races the bearing sit in if I do? Any on euse the AllBalls bearings on a Beta? Are they better than stock? Plan on redoing this winter when the snow sets in, just want to get a few more rides in. Thanks Tom
October 28, 201313 yr Replace them now they deteriote fast when there is play if the bearing collapses when your riding it can burst the housing and wreck the hub
October 28, 201313 yr Usually wheel bearing deteriorate quickly, no one can give you a timeline with mechanical problems It's easiest to say simply, they are shot right now And Allballs is cheeeeep junk, there's a reason they are half the price of stock I would hit the auto parts store and some good quality 6004 double sealed bearings
October 29, 201313 yr Author Usually wheel bearing deteriorate quickly, no one can give you a timeline with mechanical problems It's easiest to say simply, they are shot right now And Allballs is cheeeeep junk, there's a reason they are half the price of stock I would hit the auto parts store and some good quality 6004 double sealed bearings Thanks good to know about AllBalls....Autoparts store? Can they match up the size?
