Carburettor Fuel Line
declan1999
I believe that the two nipples coming from the carb are vents. By connecting them together with a hose, you are closing the vents. This can cause a rich condition. Some people use separate hoses, some use a loop as shown but then there must be a hole somewhere in the hose to allow the vents to work. Usually the hole should point down to avoid dirt and splashed water from entering the hole in the hose and then traveling into the carb.
