March 26, 201412 yr Any experience with the S3 (wide type) and Jitse rim tapes ie easy of fitment, durability? Regards
March 26, 201412 yr S3 give by far the best protection to your rims. Make sure your rims are nipping clean before fitting and make sure you warm them with a hair dryer or if you use a paint stripping gun be careful not to overheat them. Take your time fitting and I'm sure you will be happy wi' um.
March 27, 201412 yr I put some S3 tapes on my sons Rev 80, but didn't heat them and they look like Nora Batty's tights! apparently there is a youtube video you can watch that shows you how to do it (wish I'd known before I tried).
March 27, 201412 yr If you fasten a valve stem in with a couple of nuts and sealing washers on the inside and then smear sikaflex or other neutral cure sealer on the valve and all the spoke nipples you can do away with the rim tape altogether. The sealer replaces the rim tape Rim has to be well cleaned first
