rhyds115 Posted May 16, 2014 Share Posted May 16, 2014 I have a beta 250 2008 rev 3 and I'm changing the oil how much oil to put back? Thanks. Quote Link to comment Share on other sites More sharing options...
greychapel Posted May 16, 2014 Share Posted May 16, 2014 half way up the sight glass? Quote Link to comment Share on other sites More sharing options...
southwester Posted May 16, 2014 Share Posted May 16, 2014 The owners manual sais 550ml but people put in 500ml I think you'll find. The other thing that's bs in that bog paper is the fork oil measurement with spring in, its with spring out! That's from the Beta uk site somewhere. Good luck Quote Link to comment Share on other sites More sharing options...
rhyds115 Posted May 16, 2014 Author Share Posted May 16, 2014 I have got 20w/50 oil is that okay to put in the bike? Beta 250 rev-3 "08" Quote Link to comment Share on other sites More sharing options...
southwester Posted May 16, 2014 Share Posted May 16, 2014 Don't know mate, is it light gear oil? Quote Link to comment Share on other sites More sharing options...
rhyds115 Posted May 16, 2014 Author Share Posted May 16, 2014 Not sure. It says multigrade 20w/50 on it. Quote Link to comment Share on other sites More sharing options...
rhyds115 Posted May 16, 2014 Author Share Posted May 16, 2014 Quote Link to comment Share on other sites More sharing options...
southwester Posted May 16, 2014 Share Posted May 16, 2014 If in doubt buy the specific stuff online or at a shop unless someone can tell you its suitable. The putoline light gear oil ive used is about a £10 and ive been changing it about every 15 -20 riding hours, I had a motul-putoline cocktail in there for a while which didn't help the auto take off on the first pull away of the day that didn't happen once I used pure putoline! Quote Link to comment Share on other sites More sharing options...
southwester Posted May 16, 2014 Share Posted May 16, 2014 lol doubt it mate it sais motor oil on the front!!!! Quote Link to comment Share on other sites More sharing options...
rhyds115 Posted May 16, 2014 Author Share Posted May 16, 2014 Do you think 15w/40 will do as I have a competition tomorrow and ran out of oil. Typical. Thanks Quote Link to comment Share on other sites More sharing options...
southwester Posted May 16, 2014 Share Posted May 16, 2014 I don't know, my guess would be that it would be to thick. Have you drained what was in there and disposed or does it need changing that bad? Quote Link to comment Share on other sites More sharing options...
p@ul250 Posted May 16, 2014 Share Posted May 16, 2014 (edited) The 15w/40 should be OK for a ride or two. But the clutch may drag a bit from cold Oil viscosity is measured by weight, hence the W in 40w so 75w oil is actually thicker at temperature than the 15w/40. A multigrade oil acts like a thin oil when cold and a thick oil when hot. I.E in this case 15 weight Cold / 40 weight Hot. I used to use Putoline 75w gear oil but have switched to 5w/30, Beta recommend 10w/30 oil. You will find that the gear change is a lot smother with that than 75w gear oil. Edited May 17, 2014 by p@ul250 Quote Link to comment Share on other sites More sharing options...
greychapel Posted May 16, 2014 Share Posted May 16, 2014 thought gear oil had lead in it to withstand extreme pressure (as with meshing gears) while engine oil is designed to maintain viscosity at higher temperatures, it does not get thicker, at higher temperatures but does not get as thin as a "straight" oil would.....I may be wrong of course...it has been known! Quote Link to comment Share on other sites More sharing options...
p@ul250 Posted May 17, 2014 Share Posted May 17, 2014 Graychapel, I don't state that it "Gets Thicker" I state the a 75w oil IS thicker at temperature than a 40w oil. The polymers in modern multi-grade oils counteract the thinning caused by heating allowing an oil to ACT like a thin 5w oil when cold and a 40w oil when hot. Lead in gear oil? The point of highest pressure/stress in an engine has to at the big end bearing on the start of the power stroke. All the Power on one bearing with no reduction what so ever. Beta recommend BARDAHL 10W30 oil for the Evo, which is basically the same engine as the Rev. I have been using a high spec 5w30 as I find the clutch drags a bit less from cold. I have also found that gear changes are smother & more positive now than when I was running a 75w gear oil. 1 Quote Link to comment Share on other sites More sharing options...
slicktop Posted May 17, 2014 Share Posted May 17, 2014 Does the oil need to be wet clutch type, and is dino or synthetic preferred? Quote Link to comment Share on other sites More sharing options...
