August 20, 200521 yr i was thinking of buying a good used 300 pro,however i have chance of agood 04 raga replica 300,iknow from reading previous posts that in standard raga ignition setting that this machine is too fierce for most riders of less than expert level ,if the ignition setting on the raga bike was set to the mildest level am i right in thinking the bike would ride similar to a standard 300 pro?.i realise that the raga has a longer tailpipe and kehien carb but are there any other engine mods?. cheers!
August 20, 200521 yr i was thinking of buying a good used 300 pro,however i have chance of agood 04 raga replica 300,iknow from reading previous posts that in standard raga ignition setting that this machine is too fierce for most riders of less than expert level ,if the ignition setting on the raga bike was set to the mildest level am i right in thinking the bike would ride similar to a standard 300 pro?.i realise that the raga has a longer tailpipe and kehien carb but are there any other engine mods?. cheers! <{POST_SNAPBACK}> That's about it. No other significant changes. With the ignition reprogrammed to a mellower setting, you should get on fine. The Carb is nice
August 21, 200521 yr That's about it. No other significant changes. With the ignition reprogrammed to a mellower setting, you should get on fine. The Carb is nice <{POST_SNAPBACK}> I'd echo that. The Raga has the Ohlins shock and its a tad lighter if it falls on top of you, too!
August 21, 200521 yr Author thanks for your input guys.! sounds like a nice bike ,i think i will go for it.
August 31, 200521 yr hi, i have just bought a raga and it is absolutely mint to ride ,definetly worth buying! james
