hammo Posted November 12, 2014 Share Posted November 12, 2014 I took my 2003 gasgas txt pro 250 for the first time last weekend , decided to try to learn to wheelie , the wheelies got bigger and bigger until eventually I flipped it and in the process snapped my back mudguard and seat unit , where can I get a full set of plastics from and how much will it cost , ? Cheers hammo Quote Link to comment Share on other sites More sharing options...
bilks Posted November 12, 2014 Share Posted November 12, 2014 Try this guy Richard Allen tel no 07917406313 or 01933314145 he's always breaking trials bikes. 1 Quote Link to comment Share on other sites More sharing options...
steve_earle Posted November 12, 2014 Share Posted November 12, 2014 Im very sure the plastics and airbox will interchange from 2002 up to 2010. The air box lower is quite cheap new http://www.splatshop.co.uk/gasgas-air-filter-box-lower-part.html. The main reason they break is they are fixed with a couple of small screws so they just come apart and break in a flip, Somtimes they are siliconed together and that helps a bit. The best thing to do is take them apart and use polyurethane sealer such as Tiger Seal to bond the 2 halves together, This will make them 10 times stronger and maybe you will only break the mudguard on the next flip. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted November 13, 2014 Share Posted November 13, 2014 (edited) Also use tieraps to lock your mudguard in place, these will brake easier most of the time so saving your mudguard Edited November 13, 2014 by crazybond700 Quote Link to comment Share on other sites More sharing options...
casperrasper Posted November 13, 2014 Share Posted November 13, 2014 Use your back brake next time it will save you some money ...£££££ ..plastic weld you will be doing it again 1 Quote Link to comment Share on other sites More sharing options...
