November 16, 201411 yr Strange, just been getting her ready to drop off to be blasted and powdered coated and was checking the frame number details and found blue under the black, odd? The blue paint is 'in' the frame numbers suggesting it has may of been blue from new, yes, she could of been blasted & repainted back years ago but I know from doing this myself with very fine beads it can be a very difficult to get the old paint 'out' of the numbers. This attracted my interest and further inspection shows some more of this blue in some of the deeper frame treads where bolts don't seat right in and take the paint 'out'. Also the front mudguard stay that is now black was blue with blue paint 'in the bolt holes... The swinging arm doesn't show any blue at all. I thought blue frames were came out in 1982 with the frames that had the rear mudguard hoops removed? The blue is quite a bright blue - brighter than the Pernod blue - but with the matt finish taken off it becomes slightly darker. Not a problem either way but I thought I'd share that with you guys and wondered if anyone else had come across this? Edited November 16, 201411 yr by iconic558
November 16, 201411 yr Completly OK, my 1980 SWM has the same "undercoat" and too there is no such blue base coat at the swing arm.
November 17, 201411 yr Author Blue primer.....I've never seen that before. Must be an Italian thing...got to look good even in primer! Many thanks for clearing that up.
November 17, 201411 yr Author Completly OK, my 1980 SWM has the same "undercoat" and too there is no such blue base coat at the swing arm. Now thats a clean bike!
