August 24, 200521 yr How do you adjust the ignition to ride different terrains.Ive had so many varied answers i am confused if it can be changed or not?Can i buy the gear and do it myself ?HELP ME PLEASE...............................................
August 24, 200521 yr The 04 Raga does have a re-programmable ignition but you need some software and the leads to do it. It is a very simple process (if you have a laptop). There are 4 pre programmed settings to choose from all giving slightly different charachteristics. As it happens i had an 04 Raga and i bought the gear to do it. It cost about
August 26, 200521 yr Author Thanks Nickerlias for your response.Can you explain what type of curve the lower curve is.For example is it about 30% less throttle response ????? More top end?? slower midrange??? THANKS.
August 27, 200521 yr GasGasBoy, the programming effects the ignition advance curve. The changes are not super dramatic, but very noticable for sure. The mellower curves make for a much smoother, less abrupt power characteristic, particularly off the bottom. Here's a graph of the various curves for referance.
