Intake Spacer Broken
So I've managed to split the intake spacer between the carb and cylnder block.
Does anyone know where I could purchase one?
Alternatively is there a heat resistant glue that i could use to repair it?
Doh, Doh, Doh....
Thanks P@ul250
Perfect, I'd found a site in spain but a UK one is much better.
It's 1978 Cota 247 that I have.
Hi Shaun,
That's the Spanish site I found. I'm in the UK so will give the InmotionTrials a call on Tuesday.
I'll put some pictures up too.
Thanks for your replies.
I have an Enfield bullet, it uses the same rubber mount. I use the Enfield more often than the Montesa. The rubber split and I took the rubber from the Mont, that split as well. At the time (two years 3000 miles ago) I cleaned and superglued ( ordinary stuff from a pound shop) the split tube together. The difference now is that I made up a metal bracket to stop the carb wobbling around so much.
