April 19, 201511 yr I'm looking to make my TY175 road legal and have got the original lights working but not the horn. I've tried a good quality 6v horn but no sound. I'm guessing it doesn't like the Alternating current non-regulated voltage electrics. Has anyone got any tips?
April 23, 201511 yr Author I'm not sure my digital meter can handle the AC the TY gives out. I've done a bit more digging and apparently there are AC and DC horns. Most are DC, and AC ones are/were fitted to things like old Vespas and they make a noise like a duck call !! So it looks like I need to either fit an old scooter horn or wire a small battery in for my DC horn. Edited April 23, 201511 yr by dpyam
April 23, 201511 yr A digital meter should be able to handle both ac and dc just set dial to ac symbol which is a sine wave, (dc is a solid line with a dotted line underneath). If you are still in doubt then connect a 6v bulb to horn wires and if it lights when you press the button you have voltage. If you wire in a battery permanently you'll need a voltage regulator and a rectifier. Alternatively just fit one of these
May 6, 201511 yr Author Good news folks - we have an MOT! I stuck with the original electrics after working out the wiring, fixing the switch, and got an AC horn off ebay. It's barely louder than the engine though :-( I've since seen motoduro sell one that looks a better bet. Mud here we come :-)
December 3, 20214 yr I had a simi;iar problemo on a a iids 2 sroke quad, used a mosfet and capacitor to drive the dc horn. you will have issue with led lights too, got around this also HTHAPYITRD!
