ajock Posted May 21, 2015 Share Posted May 21, 2015 Would anyone know if standard ty250 bushes fit majesty, if not where can i source some. thanks for your help. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 21, 2015 Share Posted May 21, 2015 yes the Yamaha OEM TY plastic bushes fit the Godden Majesty 250/320 swingarm. I did find that I had to slightly shorten the inner bush (the steel one) that came in the kit from John Cane. Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted May 22, 2015 Share Posted May 22, 2015 yes the Yamaha OEM TY plastic bushes fit the Godden Majesty 250/320 swingarm. I did find that I had to slightly shorten the inner bush (the steel one) that came in the kit from John Cane. I had to do the same with the alloy one from Majesty UK. Must be a common thing ? Weird Quote Link to comment Share on other sites More sharing options...
woody Posted May 22, 2015 Share Posted May 22, 2015 Not sure if it is the reason why you had to do it, but from memory, the Godden swingarm is narrower across the spindle than the TY frame Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 23, 2015 Share Posted May 23, 2015 Very likely to be the reason woody. From memory it was about 1mm that had to come off the steel spacer Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted May 23, 2015 Share Posted May 23, 2015 When i did it it was really weird. The tube was a perfect fit in the frame but that was without the dust covers. They were 1.2 mm thick so thats what i had to machine off both ends. Seems as if somebody measured the gap across the frame and forgot the dust covers. Whatever now it fits perfectly 1 Quote Link to comment Share on other sites More sharing options...
