October 22, 201511 yr If it had one I could replace it. Rotax 125's have got CDI ignition. You do, that's what the c in cdi stands for. Capacitors and condensors do the same thing, try and borrow a unit to swap.
October 22, 201511 yr Ok, so a blackbox(or whatever colour) swap is what's implied not a simple condenser as on the larger Rotax motors. It just so happens that.........I have a spare one in the garage. We shall see. Thanks to you all thus far for your help.
February 8, 201610 yr It wasn't the and#39;blackbox' I found some other interesting information regarding the Dell'orto PHB carbs and what's used when and where. So, I reduced the idle valve jet size, when do you run at full throttle for long periods nowdays with a not street legal bike ? Anyway, you live and learn, Added the pdf in a later entry. Worth reading for anyone with carb probs. Edited February 8, 201610 yr by brownie001
February 8, 201610 yr I can't get the mail to accept the pdf concerned ?!? dellorto_motorcycle_carburetor_tuning_guide.pdf
