Flywheel Settings?
michel
These are for a 240 , but you'll get the Idea ...
Main gear sprocket
Nut 14mm : 70/90Nm
Ignition rotor
Nut 15 mm : 65/70Nm
Head cylinder
4 screw 9mm : 30/35Nm
Engine (front)
Spindle 10mm : 50/60Nm
Engine/Swingin arm spindle
4 screw 8mm : 25/30Nm
Gear box covers
screw 6mm : 9/11Nm
Cluth
Nut 16mm : 80/100Nm
Shock aborbers
4 screw 8mm : 19/22Nm
Front wheel
Spindle 15mm : 39/44
Rear wheel
Spindle 17mm : 98/117NM
