Ty 250 Mono Power Issues
Hi, my ty 250 mono was running flat, had both my mx race bikes stolen so funds have been an issue of late but finally i took the top end apart and put in new piston rings, piston looked fine and barrel had minimal scoring
Ran in the bike today (whether i needed to or not with just the rings) it DOES have a little bit more power but It's definitely still not at full power
What could be causing the bike to run so sluggish? Could anything to do with the carb be the issue? It literally starts 1st kick
Thanks
First of all sluggish compared to what ? Part of that bikes success was it's lack of power which helped lots of people find grip without ever having throttle control, including me.
For example a 240 Fantic in my view had more power although it's was only a 212cc. A 300 Fantic or 240 swm had more power by some margin.
Compared to your mx bikes it would be more like a 125.
So to help you why do you think it's flat, what are you comparin to ?
Is the exhaust clear? No severe carbon build up or dents stopping the flow of exhaust gases?
Well my ty 175 has much more power, put it that way
No dents, i burnt the exhaust out to clear the carbon build up
Also it use to have more power when i first got it im sure... I don't know what it is im even contemplating buying another one because i loved riding it when it was at full power, more than mx!
Whilst a good carb clean won't do any harm I have known the perforated tube in a silencer to either fracture or come loose such that it falls down and no longer link the two ends of the silencer, causing an obstruction.
I appreciate you thinking in such depth, but i have tried various silencer also, including a 'wes' silencer
Edited by dannyboi
Does it rev cleanly or sound choked ? When the coils on the stator start to fail the bike won't rev very high
Burn the exhaust on a mono ? I tought it was not possible.
Guy
It does sound abit choked, like as if it's not getting enough fuel to build the revvs higher
How could i check to confirm it's the coils?
Yes I literally took the exhaust off, barbecued it hah my dad showed me a little trick to burn out the inside, sounded like a jet engine when he did it
