Ossa Misfire
If it is the ECU at fault, you can replace it with another ECU with either the earlier or later firmware. The earlier firmware does not support the easy start system, which is no big drama. The later firmware can be "flashed" into your existing ECU or into an earlier firmware ECU by a company in Spain. I have had this done, installing the later firmware on a 2012 ECU but must say that it took about as long as building Hadrians wall. Minimal cost.
PM me if you would like more info.
Also, not sure if I posted this before, but we did have a problem with an intermittent break in one of the wires going into the ECU, right on the tight angle where the connector clips into place.
Bye, Peter B.
  • Replies 53
  • Views 14.1k
Most Popular Posts
  • gasgas249uk
    gasgas249uk
    There is always an element of guesswork. Have you spoken to Birkett ?. He should be able to have a go diagnosing it on the phone. It'll be the injector though . £100 unfortunately
  • There isn't a history of the fuel injector failing on the Ossa, but still is probable. We have had 2 cases with Ossa's where the ECU terminals at the connector were oxidised/coated/dirty, cleaning wi
Have you tried new fresh petrol, fuel filter condition and fuel pump pressure?
Take the bike to a local automotive diagnostic technician and ask him to check the HT voltage waveform. Should take less than 5 minutes. Most if not all of the Ossas EFI and ignition components can be easily disconnected and individually tested. If bike was mine I would check all the components one at a time and continuity / resistance (under load) in the wiring harness.
ECUs are solid state and generally very reliable
Check the stability and values of the regulated voltage.
Have you tried to check for a spark at the plug or kicked the bike over with the plug lead disconnected or the plug not earthed? If so this could trash the ecu.
Try phoning round ECU testers / repairers in hope that one can test your ECU.
  • 1 month later...
badger, did trials + trib sort your bike or is it in a skip.Mine has lost power,starts 1st time and revs ok but under load starts dieing.Pull clutch in and it revs up again.
Yes trials and tribs are very good they know there stuff ,sound like the tps needs re setting or clean the tps connection to the throttle body or could be a loose connection to the fuel injector check all your plugs what year is the bike
That's good news,mines a 2011.Had it 18months.been great till now.Thanks for the suggestions.I am only 30miles or so from trials and tribs if I cant cure it.
Just took it to trials and trib,hope they can sort it.What was wrong on yours in the end badger?
Needed a new throttle body and tps re setting ,Trials and Tribs will fix it Ian knows his stuff
