jj46 Posted July 10, 2016 Share Posted July 10, 2016 So I got my daughters 80 out of the van today, started it up and discovered she had no clutch. It was fine the last time it was ridden but today the lever had no effect. It didn't feel any different but I bled it through however this didn't make any difference. She wanted to try it with no clutch and within 5 minutes the clutch was operating perfectly and continued to do so all afternoon. I've just unloaded everything and thought I would check it and once again there is no clutch... Any ideas? 1 Quote Link to comment Share on other sites More sharing options...
copemech Posted July 11, 2016 Share Posted July 11, 2016 (edited) Are you saying the clutch will not disengage? Clutch plates sticking together in a trials bike is common. Fresh gear oil helps many times. So does placing into a higher gear, pulling lever and rocking the bike prior to startup to insure they break free. Edited July 12, 2016 by copemech Quote Link to comment Share on other sites More sharing options...
jj46 Posted July 12, 2016 Author Share Posted July 12, 2016 Thanks Copemech, never known them to stick like this before but fresh oil seems to have sorted it. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted November 25, 2016 Share Posted November 25, 2016 My daughters 06 Beta Rev 80 has the same issue, the longer between rides and oil changes the more often it happens. Just a little riding with the clutch pulled in an it sorts its self every time. As you indicated when it starts happening a lot in short order I change the oil and its better. Quote Link to comment Share on other sites More sharing options...
