August 15, 201610 yr hi guys just wondering if i can use a WM2 rimlock in the front( as i happen to have one handy) in a bog standard 200.fantic many thanks in advance cheers murray
August 16, 201610 yr I think it might be a little bit too wide. A WM2 is 1.85 inches and a WM1 which is what you want is 1.65 inches. Just try it and see if it fits in there. Graham.
August 16, 201610 yr Author thanks graham it does look a wee bit wider--- will just order up the right thing . cheers murray
