t20racerman Posted October 22, 2016 Share Posted October 22, 2016 Hi all - yup, me again I just got my petrol tank back from the painters - and its oh SO nice! What a lovely paint job. The paint shop is in Ware, East Herts if you want anything painting. It's a great place :-) Anyway, I have the rubbers for the frame lugs that the front of the tank rests on, but what's at the other end? There is a rounded bracket at the back of the tank that seems to sit snug on the top frame tube, but should there be something under this? Is there supposed to be a rubber or something under the tank? Should finally have it running and fired up this week - for the first time in over 16 years. Yay! :-) Adrian 2 Quote Link to comment Share on other sites More sharing options...
spen Posted October 22, 2016 Share Posted October 22, 2016 Looking good Adrian. 1 Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted October 22, 2016 Share Posted October 22, 2016 Lovely paint job on the tank, what colour is the frame and other parts? The tank sits on the rubbers at the front then held in place by the seat but it needs rubber between it and the frame aas well as the seat if possible to avoid metal to metal contact or chafing on the seat base. Hope you post pics when it is finished. Quote Link to comment Share on other sites More sharing options...
woody Posted October 22, 2016 Share Posted October 22, 2016 As above, it's the seat that holds the rear of the tank. If you have the original seat it does the job fine but if it is a Miller seat it probably won't fit snugly against the tank so you can use a releasable cable tie of jubilee clip etc across the tab to hold the back of the tank. You'll also need something under the tank as if you just sit it on the frame tube it will move around and vibrate like hell. You can use the foam tubing that is sold for pipe lagging or use rubber strips cut from old inner tubes etc. Originally they had foam pads or something to stop the vibration. Beautiful job on the tank Quote Link to comment Share on other sites More sharing options...
bondy Posted October 23, 2016 Share Posted October 23, 2016 (edited) Had a problem with my seat its a Alloy base 1 original but for some reason it wouldnt go fare enough foward so i had to use the 1 that came with the bike the base that is made fron firbre glass i just took the foam and seat came off and recovered the other base i have a spare base and cover. reading your thread as made me think i dont think i put the rubber back so ill have to take it off again. lovely paint job. the bike looks better I've since polished the rims replace the rear shocks New piston New chain and sprockets. Edited October 23, 2016 by bondy 1 Quote Link to comment Share on other sites More sharing options...
t20racerman Posted October 24, 2016 Author Share Posted October 24, 2016 Thanks for your help guys - very useful Fired the bike up today for the first time and it ran lovely! Job not finished yet, work to do, but it was nice to fire it up. Will post photos when done. :-) 4 Quote Link to comment Share on other sites More sharing options...
