Whine On A 2013 300Cc Factory Replica
it only had a new clutch fitted in Feb 2015
Correctly? Good quality and adjusted properly? Not slipping?
  • Replies 38
  • Views 9k
Most Popular Posts
  • good to know for future.......we should have called Nigel 3 pages ago!
fitted by a dealer and they where the factory up dated plates, I cant feel it slipping
I like the biting point right at the end of the lever action
Take the chain off and start it up and see if you get the whine in 2nd without any load
canada280i I ran it yesterday on the paddock stand with no load and
there was no noise
This is strange then as you would think that if it was a shaft bearing it would appear in more than one gear
I'm planning i on getting a video later today
it wont let me add the video so the link to it is here
No that's with it in second gear and the clutch on and off biting point, the coolant level was ok and looked ok
wouldnt the waterpump do it all the time ?
Does the pump cover get very hot? This is why I asked about coolant Color as I had an issue once with the plastic pump impeller rubbing on the pump case which made a funny noise, and eventually ruined the pump.mperhaps the noise is more apparent at a certain revolution range such as produced by second gear. To correct this I noticed that there was no gasket on the 300 between the casing and waterpump although one was listed in the parts book. I made a thin one from gasket material (because of the wear I ultimately replaced the pump as well as the fins had worn down) and the issue was totally solved.
When I say hot I mean very hot, hotter than would ba caused by hot coolant, if it is rubbing it will get hot very quickly
Right I've just emptied out the coolant and there was no bitsin it
from the drain hole, I've taken the water pump off but cant seem
to get the circip off to have alook at the impella ?
