January 27, 20179 yr Hey guys, ive just picked up my new Mont, and getting ready for my 1st trial on it tomorrow. Ive gone from a 2008 gas gas 300, Ive been out on it a couple of times and the 1st thing i noticed was how much it pushes on in std gearing in 1st. Ive searched and read as much as i can, and see you guys recommend lowering to a 9 tooth up front, i'll see how i go Sunday with it as std. One thing that has really stood out is how nice the Showa suspension is, going over some concrete blocks that i usually go over with the gasser, i couldn't believe the difference. But hitting these blocks i did notice that my timing was out by a fraction compared to the 2t. Any advice on the bike and how to get the best out of riding the bike from a 2t to 4t would be appreciated. I ride intermediates by the way. Cheers Rob
January 27, 20179 yr You don't say what your riding ability is, but if you finding it too fast in sections in first gear, then try a 9t on the front and a 43t on the rear. That slows it all down nicely, but still allows you to do most things in first gear (depending on your standard).
January 28, 20179 yr I ride around the same level and found that with a little practice I like stock gearing better than with a 9T or sized up rear, however if I was going to do anything I would just go up 3 in the rear and keep the 10T in the front as the 9T is a bit harder on chains. As for timing its just a practice thing, I was on a 2T to start with and got my Montesa and found that I adapted quick just by riding it a lot. --- Some things that I think have helped me... To practice larger obstacles with a small pre compression bounce on the front before the full compression bounce, seemed to help me with a combination of the up as well as throttle and timing. I also found being a little earlier on the throttle with more clutch work helps me as well. I have also found that I really like using the mid range power and so often find myself shifting up to second and using less throttle and way more clutch as time progresses. I can't say this will work for you, however stock gearing, more clutch work, and using the mid range power they provides works well for me. What can I say, they ride different, they are not 2T's. I make no claims real or implied... I am sure you will do fine!
January 28, 20179 yr I went to 9 as an experiment and found it fine but, as said, cruel on the chain. I now run 10/43 and will probably stick with that, it is halfway between 9/41 and 10/41. 9/43 seems very low. I would give it a few trials first - I met a chap who runs standard gearing and uses second all the time, but it did look a bit hairy.
January 28, 20179 yr Author Thanks for the advice guys. Today is the trial so i will report back later with how it went, plus my lad is having his 1st trial on his new Trs 250.
January 30, 20179 yr Author Well, the bike and i survived our 1st trial together, it was good but frustrating for the first couple of laps. Then things started to come together especially the timing, there were a couple of short sharpe banks 1.5m vertical that caught me out early on with to little throttle. Gave it a good blast after that and up i went. Overall im a happy convert and am sure i will enjoy and learn the more i ride it.
