Big Vernier Posted March 10, 2017 Share Posted March 10, 2017 Can anyone help me? My 1988 Climber was reving very high. So I suspected an air leak. I replaced the flywheel side crank oil seal, and found a little bit of play in the main bearing that side. Now it only seams to want to run on choke, and still revs quite high. Any suggestions? I was wondering about the carb boot the that goes into the side casing?? Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 10, 2017 Share Posted March 10, 2017 Tighten it and check. What carb ? (air screw Dellorto I'll bet) 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted March 11, 2017 Share Posted March 11, 2017 Did you replace the vent tubes? Quote Link to comment Share on other sites More sharing options...
