November 25, 20178 yr here some number about real power end real weight from the italian revue Motociclismo Fantic 200 - 86.5 kg hp 13.38 - 5750rpm - torque 1.77-5250 rpm Fantic 240 - 89.5 kg (40.5 front - 49 rear) hp 14.83 - 5500 rpm - torque 2.12-4500 rpm Fantic 300 - 96.5 kg (43 front - 53.5 rear) hp 13.46 - 4500rpm - torque 2.28-4000 rpm Fantic 301 - 88 kg (41 front - 47 rear) hp 15.48 - 5000 rpm - torque 2.35-3750 rpm Fantic 303 series 2 - 90 kg (42 front - 48 rear) hp 14.84 - 5000 rpm - torque 2.51-3500 rpm Fantic 305 - 82.5 kg (41 front - 41.5 rear) hp 18.41 - 5750 rpm - torque 2.48-4000 rpm Alberto Edited November 26, 20178 yr by alberto
November 25, 20178 yr Author 13 minutes ago, baldilocks said: With hindsight why did they make the 300 so heavy ? the 300 was a mistake, Fantic need a new bike but the designer of the 240 was old and he retired, so the 300 born in run, after a few months they just tried 301 prototype
November 26, 20178 yr Are them numbers for the 200 pro? I have a 200 FM350 feels heavier than that Would like a 305 to add to the stable.
November 27, 20178 yr Author On 26/11/2017 at 8:02 PM, cangy1000 said: Are them numbers for the 200 pro? I have a 200 FM350 feels heavier than that Would like a 305 to add to the stable. the number you see are for the Fantic 200 Fm350 Minarelli engine 1979 305 it's another story, see the power and the different balance of the weight, feel very light on the rear wheel
