September 17, 20188 yr .I am the owner of a 2011 Ossa tr280i in Ontario Canada.It has the original rear hub bushing/bearing setup and it is need of a new bushing. I believe the skf # is "pcmf 353916 e".I know that there was a kit available at one time to convert the hub to bearing/bearings with a new pair of spacers.Does anyone know where i can obtain them? I tried local bearing suppliers,but they have a minimum order of $255. Thanks,Ric
September 17, 20188 yr Hi Ric, we machined out the hubs to fit ball races, 60042RS from memory, and made up a wheel spacer to suit, with the tyre off, the wheel can sit flat on a large milling machine table. Pretty sure the kit was just a sleeve and a smaller than 6004 ball race. Bye, Peter B.
September 17, 20188 yr Author 1 hour ago, ossabc63 said: Just a dumb answer, did you phone matt at dualsportplus. Cheer kim Yes.They couldn't help and referred me to Lewisport who is yet to answer my 2 emails after a week.
September 17, 20188 yr Author 36 minutes ago, peterb said: Hi Ric, we machined out the hubs to fit ball races, 60042RS from memory, and made up a wheel spacer to suit, with the tyre off, the wheel can sit flat on a large milling machine table. Pretty sure the kit was just a sleeve and a smaller than 6004 ball race. Bye, Peter B. That'll be a last resort.The bushing isn't as good,but hey,it lasted 7 years.Another bushing would be fine and no more than $10 if i could buy just one.Thanks.
September 18, 20188 yr If that is the correct part number a quick search turned up this link to order one for $20: https://www.applied.com/c-skf/pcmf-353916-e/GLYCODUR-BUSHINGS/p/101511349
September 18, 20188 yr Author 8 hours ago, lotus54 said: In general, email isn’t very useful to Lewisport. I find I need to call. Thanks guys.Lewisport finally got in touch with me.I'll see what they have.They were at the Nat's...duh!
September 18, 20188 yr https://trialstribulations.net/index.php?main_page=product_info&cPath=35&products_id=3060
September 18, 20188 yr Author 1 hour ago, ossa68 said: https://trialstribulations.net/index.php?main_page=product_info&cPath=35&products_id=3060 Thanks,but it's sold out.
September 20, 20188 yr If Lewisport or Birketts do not have the parts for you and ya do not wish to machine it out like Peter's good suggestion, should be no big deal lacing in a standard ball race hub like other brands use...maybe trials bike breakers in uk??
September 21, 20188 yr Author On 17/09/2018 at 9:23 PM, canada280i said: If that is the correct part number a quick search turned up this link to order one for $20: https://www.applied.com/c-skf/pcmf-353916-e/GLYCODUR-BUSHINGS/p/101511349 Thanks bud.They are on their way from SKF.
October 11, 20187 yr https://www.dherbeymoto.com/marchand/piece_detachee_p2.php?num_rubrique=4&num_type=134&num_produit=10818&page=piece&num_rub=4&type_recherche=moto
October 11, 20187 yr Author Thanks.I already ordered a couple of bushings,but i might order that as well.
