Bultaco parts
5 hours ago, bill black said:
Getting stuck into cleaning it all up ...
Nice one Bill, I'm just down the road from you in Dublin
Did you strip off the black coating paints on the casings or was it done previously?
I have to say getting the casing to shine using the buffing wheels give a great sense of satisfaction.
Give me a shout anytime, all the best
Pat
  • Replies 32
  • Views 10.4k
Most Popular Posts
  • Yout engine number is JM18301632  so the engine is a 183 from 1976/77,  the frame is a 199 only as it doesn't have the A at the end of the number. The 199 and 199A have different frames.   It definite
  • The swingarm bolt rusting solid is not an uncommon problem. It's unlikely you'll drive it out, normally the spindle has to be cut through either side of the swingarm which can them be removed, then yo
  • https://www.inmotiontrials.com/
Hello Pat
I used a drill and wire brush to shift the worst of the paint and I have a blast cabinet with aluminum oxide which I'm using for the head and barrel etc. I'm trying to salvage a piston out of a spare engine as piston prices are eye watering ! Have you a Sherpa too ? I am hoping to do classic trials on mine ......
Hi Bill,
Your end results are looking good. The 199A is a smashing bike and it's great to see another coming back to life. I recall about 20 in total mostly 325's and a few 250's been brought into Ireland. I have a parts manual which provides very good exploded drawings of all the components if your even in doubt about anything.
I have a slow burn restoration of two Sherpa's ongoing, I'm hoping to spend some time working on the 199B over the Christmas as I have a bit of time of work.
