Sherco 290
Hi All,
Has anyone had any problems with the water pump on the Sherco 290 motor?
I have a Sherco x-ride which runs this motor. On a recent long distance trial the water pump impeller separated from the water pump on a road section and it all went down hill from there. Looking at a new piston and barrel, plus water pump and bits. Motor had done around 3000 miles and was otherwise sound.
Interested to know if this is a common problem and if there are any fixes.
Thanks in advance.
Kev
Have seeing it. Brass thread separated from plastic part.
It was after trottle stuck open and engine rev to hell
