January 8, 200620 yr Hi all I had a trial today and i'm having problems with my front brakes always spongy even when well bled (well practiced), i was wondering if the problem is with my front brake master cylinder/resevoir is there a repair kit or method of cleaning the resevoir. thanks in advance.
January 8, 200620 yr Did you disconnect the line from the master and bleed the master itself? Somebody else also mentioned tying off the lever (applied) and leaving it over night. This firms it up a bit.
January 8, 200620 yr Also...check for damage to the hose. Even just a kink that could have damaged the hose internally. A bad spot can bulge slightly under pressure and give a spongy feel.
