DanielHowden Posted February 17, 2019 Share Posted February 17, 2019 I have been looking for information about changing the crank seals on the above bike but not found anything so far. I wonder if anyone could advise if these can be changed without splitting the cases or not. Thanks, Daniel. Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted February 17, 2019 Share Posted February 17, 2019 The only seal that needs to split the cases is the kickstarter one. Quote Link to comment Share on other sites More sharing options...
sdm Posted February 17, 2019 Share Posted February 17, 2019 Yes they can be changed without splitting the cases. You will need a magneto flywheel puller for the magneto flywheel, and a good stout puller to pull the primary gear on the clutch side. There are seal housings that unbolt from the main engine cases making seal replacement very simple. Sam 1 Quote Link to comment Share on other sites More sharing options...
DanielHowden Posted February 17, 2019 Author Share Posted February 17, 2019 Brilliant, thank you for the info. Quote Link to comment Share on other sites More sharing options...
riffraffretro Posted February 22, 2019 Share Posted February 22, 2019 Really straightforward job... save for removing the primary gear from the crank shaft - brace yourself! There's many a helpful guide on how to, here on TC. 1 Quote Link to comment Share on other sites More sharing options...
