evo boy Posted February 26, 2019 Share Posted February 26, 2019 I have a BSA B40 running tiger cub wheels could anyone please tell me when they do the conversion do they use the B40 chain and sprocket or the tiger cub? It's running a DID428 chain. Many thanks Quote Link to comment Share on other sites More sharing options...
teamferret Posted February 26, 2019 Share Posted February 26, 2019 428 Chain is fine for this application, so leave as is. You might want to consider moving the sprocket away from the wheel slightly as usually the chain runs very close to the tyre. Check wheel alignment first but I suspect this will improve it 1 Quote Link to comment Share on other sites More sharing options...
evo boy Posted March 1, 2019 Author Share Posted March 1, 2019 (edited) On 2/26/2019 at 12:49 PM, teamferret said: 428 Chain is fine for this application, so leave as is. You might want to consider moving the sprocket away from the wheel slightly as usually the chain runs very close to the tyre. Check wheel alignment first but I suspect this will improve it Thanks for the reply. I need to replace the rear sprocket and chain but don't know what there from ie BSA or triumph Many thanks Edited March 1, 2019 by evo boy Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted March 1, 2019 Share Posted March 1, 2019 On 2/26/2019 at 11:19 AM, evo boy said: I have a BSA B40 running tiger cub wheels could anyone please tell me when they do the conversion do they use the B40 chain and sprocket or the tiger cub? It's running a DID428 chain. Many thanks I buy from this link https://www.trialsbits.co.uk/index.php?cPath=78_107 hope this helps 1 Quote Link to comment Share on other sites More sharing options...
evo boy Posted March 1, 2019 Author Share Posted March 1, 2019 1 hour ago, trialsrfun said: I buy from this link https://www.trialsbits.co.uk/index.php?cPath=78_107 hope this helps That's a great help thank you I'm going to call them tomorrow and order what I need. Many thanks again 1 Quote Link to comment Share on other sites More sharing options...
evo boy Posted March 2, 2019 Author Share Posted March 2, 2019 Would anyone know which is the best sprocket set up for a B40 14 tooth front and 60 tooth rear? Many thanks Quote Link to comment Share on other sites More sharing options...
trialsrfun Posted March 2, 2019 Share Posted March 2, 2019 (edited) 2 hours ago, evo boy said: Would anyone know which is the best sprocket set up for a B40 14 tooth front and 60 tooth rear? Many thanks If you feel the current gearing is too high then either go smaller on the gearbox or larger on rear wheel, I assume the sizes you quote are for 428 chain, is this the chain size on your bike 520 is also listed? 520 links are longer but slightly thinner than 428. If you divide the number of teeth on the gearbox sprocket into the number on the rear this will give you the ratio. 428 chain 60÷14=4.28 I think trialsbits sell a smaller engine sprocket which would lower the primary gearing best to be certain what you have then speak to trialsbits. Edited March 2, 2019 by trialsrfun Quote Link to comment Share on other sites More sharing options...
