Tiger cub head removal
Do you have to take the front engine bolts out?
The head nuts are the long type which I assume makes the studs shorter, so should give a little more clearance.
I’ve always taken the engine out as it doesn’t take that long.
I also put an access hole and made a cover in the head where the top of the pushrods are to help reassembly. Use elastic bands to hold rockers up on assembly.
  • 1 year later...
I've taken mine off twice recently with no issue, however, you might want to take the rocker arm covers off first.
