Tx 240 engine
Hello
It's wonderful to join you all
I have a tx 240 but the disc valve came loose and jammed,
I would say it's a catastrophic engine failure as the flywheel slipped, crank gears slipped, disc valve broke in 2. Flywheel previously welded on and crank taper is in bad shape.
Cylinder and piston are fine and bearings all ok
Where would I start looking to get a rotax 240 engine to replace my old one or part to fix her.
I bought a rotax 122 engine but it would require some fabrication to work- drive sprocket won't fit its too low for the chain. We're worried about the strength of the frame if we start cutting.
What alternative engines are there for this job. Preferably 2t but if 4t is easier and fresher and has been done before. It's not for competing just a project but due to the age of her we want to do it right
This bike is the same as a swm gori and Armstrong
The sprockets are on the right if your sitting on the bike
I am open to your ideas and any help would be much appreciated
Many thanks
Kdtx240
Edited by Kdtx240
  • Replies 33
  • Views 15.3k
Most Popular Posts
  • Thank You all for your replies Thankfully the points in ignition system is working The magneto is a bit tired but it still makes power Hopefully should be able to get parts to build her
  • Hello everyone It has been a while since I posted  During this time I have been sourcing a new engine The bike was almost burned in a fire but it escaped untouched and is securely locke
  • Hey everyone  so the last 2 Saturdays have been spent on the tx 240 got the exhaust on had to timesert a rung head stud this was not fun at all made a chain slider i need an a
1 hour ago, teamferret said:
i've heard of the climber bottom end being used
Easy to do, problem is electronic ignition is now getting old on climbers. Better with a point ignition which can be swapped for a new electronic if required.
Hopefully should be able to get parts to build her up
Will post updates for you all , may be take some pictures so we can all enjoy the upcoming build
The tx 240 has been a challenge but a very enjoyable one.
  • 6 months later...
Hello everyone
The bike was almost burned in a fire but it escaped untouched and is securely locked away now
A tx312 engine has been sourced and will be fitted in due course
Will post updates as they happen
Thanks all
  • 5 months later...
Hello all
The engine has arrived and is in my possession. Due to the way things are at the moment I can’t get to the frame to get the engine in. However patience will win and I’m not putting my dearest friends at risk over a bike.
Allen’s used trials spares got the engine for me for which I am very grateful.
Here is the engine
I am also building at a 1992 kx125 9279B692-AE50-4F91-9530-99BF6819FD99.thumb.jpeg.99c78a835f7776328e64c8d0924bb2ef.jpeg1D735633-1F5F-4205-AF56-8BF6A06A50DC.thumb.jpeg.233397abac785dff3349493ff1cbafad.jpeg
and a 1990 CR250
Hopefully these photos and the much awaited news of an engine for the tx will lift your spirits in these challenging times.
If you would like more information about my bikes please ask
Just an update on the kx 125
Engine is in
Has spark after full rebuild
Need a radiator hose so go to parts store on Monday
Build the rest of her and try start
Kawasaki seems to have aged better than the Honda but the Honda is a simpler machine
May try and get the tx 240 frame and keep up the good momentum
Update on kx 125
Near all built.. have managed to lose the front sprocket
getting close to the first start.. I’m a bit nervous because I’ve a lot tied up in this little 125
After the kx is complete it can come off the stand and the tx240 can begin
it all began with the tx240 and a can do attitude and asking questions
there is a ty80 for sale in my area for 900 is that a good deal?
Here are some bonus photos
regards
kdtx240
Update on tx240
frame is home
will take a day to remember a bit about the bike.. looks a very simple bike
few bits to tidy up 2 quite awkward jobs to do. One drilling out a engine mount bolt on frame. other is wiring
frame is in my shed ready for building
Update on tx240
Engine is in
I need to rotate the intake boot to the outside by a bit less than 180 degrees as the motor is actually off a Swm hoping if i loosen the clutch cover it will just move a bit.
Front engine mounts may need to be adjusted but it's held by one stud so it's going nowhere
New points on the motor and every bearing has been done in the bottom end. This motor also makes a lot of compression.
Plan is
to get the engine fully mounted by either making new front mount brackets or play around with the ones there
Trace the pickup or signal from the points and get spark
fire her up
Make a chain slider
Put chain back on
Go test ride
Tidy up front forks do seals
Tidy up few wee bits
Then enjoy the tx240
I may not repaint her only cover bare metal but leave her vintage
Tldr : engine in.  bit of adjustment needed but very minor work.
Party on
Good evening all
Tonight I spent some mechanic time with my tx
I was able to take off the clutch cover and move the intake boot so that the carb would go on. All that holds it on is a hose clamp. One of the dowels is actually a bolt hole too.
I got the engine mounted apart from the broken stud. It will need an m6 nut welded on, heated up and slackened that way. It took some prying with a prybar to get it lined up. It was either the heat of the fire or just the Italian way. Here I called on my experience of fitting gearboxes to cars along with my experience of bikes.
I think the next step is to get spark and start her up
I feel the broken stud can wait to such times suited to delicate work
I really do feel we are getting very close to the first start
I do notice this is a very large cylinder, I think it's a 311 engine it's definitely the largest displacement bike i own now. If anybody knows what the actual cc is please advise.
I can't praise enough how good of a job has been done with the engine i think the crank has even been rebuilt it is basically a brand new engine.
Will keep you all informed
Regards
Kdtx240
Edited by Kdtx240
Hello again
Got the carb on and figured out the wiring.
We now have a nice strong spark
seems to take very little speed of kick to make a spark.
Have hit a problem with the exhaust not fitting.. Shouldn’t be too big of an issue.
we’ve got spark, the carb works so we’ve fuel and we’ve compression.
will keep you all informed of new work.
regards kdtx240
  • 4 weeks later...
Hey everyone
got the exhaust on
made a chain slider
i need an air filter may fit a k&n to the carb and not need any air box
and the decompression valve had to be removed to fit the old tx 240 exhaust to the swm 280 head
the bike creates a lot of interest now due to its age and “footery” work
regards
karl.
