4RT compression test (SOLVED)
7 hours ago, ivanrs01 said:
can it be a good idea to clean internally the body of the injection?
Can't hurt, but may not help.  Does it run well other than difficult starting?  If so, it's probably not the injector.
problem solved, the previous owner had to change the cover of the ignition, not pass the wires of the coil and one scrubbed with the magnetic steering wheel, I repaired the cable, I have placed it in its correct place and my 4rt turns on the first kick
thank you all for your help I have learned a lot these days
