evo boy Posted June 24, 2019 Report Share Posted June 24, 2019 Morning all could anyone please tell me how to set up the 4 clutch springs? I know on some you tighten them all the way then back them off 4 turns but not sure about the bsa. Also should they be wired once set up? Many thanks Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 24, 2019 Report Share Posted June 24, 2019 All the way in and back out a few turns, then with cover off, clutch in. Kick it over and check plate is parallel with basket. Adjust till it is. Mine was wired. 1 Quote Link to comment Share on other sites More sharing options...
jon v8 Posted June 25, 2019 Report Share Posted June 25, 2019 Be a good idea to get hold of a copy of the Rupert Ratio engine manual,everything you need to know is in there. http://www.ratiopublishing.co.uk/ Quote Link to comment Share on other sites More sharing options...
evo boy Posted June 26, 2019 Author Report Share Posted June 26, 2019 (edited) On 6/25/2019 at 7:56 AM, jon v8 said: Be a good idea to get hold of a copy of the Rupert Ratio engine manual,everything you need to know is in there. http://www.ratiopublishing.co.uk/ I'll do that thank you as I bought a Haynes manual but it's not very good. Which one would you recommend for a WD B40? Edited June 26, 2019 by evo boy Adjustment Quote Link to comment Share on other sites More sharing options...
evo boy Posted June 26, 2019 Author Report Share Posted June 26, 2019 Also I've fitted the clutch basket clutch ect back together but the outer part of the basket seems to have in and out movement is this normal? Many thanks Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 26, 2019 Report Share Posted June 26, 2019 2 hours ago, evo boy said: Also I've fitted the clutch basket clutch ect back together but the outer part of the basket seems to have in and out movement is this normal? Many thanks Take or leave advice, but at least have the courtesy to acknowledge it. Quote Link to comment Share on other sites More sharing options...
evo boy Posted June 26, 2019 Author Report Share Posted June 26, 2019 54 minutes ago, b40rt said: Take or leave advice, but at least have the courtesy to acknowledge it. Hi b40rt sorry if I offended you it wasn't meant to. Thanks for the advice its much appreciated. 1 Quote Link to comment Share on other sites More sharing options...
