grib Posted January 18, 2006 Share Posted January 18, 2006 Is this Hebo flywheel weight for the Pro an alternative to the one sold by GG UK or is it just for a different model than the one shown on the GG site? Quote Link to comment Share on other sites More sharing options...
jordi Posted January 18, 2006 Share Posted January 18, 2006 Looks pretty much the same, where is that one sold? Quote Link to comment Share on other sites More sharing options...
grib Posted January 18, 2006 Author Share Posted January 18, 2006 The Hebo one is from BVM, looks quite different from the one on the GG site, the Hebo one looks as if it is held in place by one central bolt but the GGUK one has a hole about 50mm diameter in the middle and is held on by 2 M6 screws. Quote Link to comment Share on other sites More sharing options...
grib Posted January 23, 2006 Author Share Posted January 23, 2006 What are all the other holes for? Quote Link to comment Share on other sites More sharing options...
magicmat Posted January 23, 2006 Share Posted January 23, 2006 What, so that kit is to actually make the flywheel heavier ?? to make for smoother power delivery ?? Quote Link to comment Share on other sites More sharing options...
grib Posted January 25, 2006 Author Share Posted January 25, 2006 That ferret doesn't look too happy! Quote Link to comment Share on other sites More sharing options...
magicmat Posted January 30, 2006 Share Posted January 30, 2006 couldnt adding more weight be a bad thing?? as you are affecting the balance, between the flywheel and the counterweight, (yes i know the counter weight is alot smaller/ lighter anyway, but are you not putting extra strain on your main bearings heading for an earlier bottom end rebuild? Are these a larger problem with them? Quote Link to comment Share on other sites More sharing options...
