rev 3 fork oil change
Hi, can anyone advise if there is a simple way to change the fork oil in a beta rev3 (2003) with out a strip down
cheers Neil
I seem to remember spending about ten minuteson the operation: removing the front wheel and mudguard then, having removed the top nuts, sliding the stanchions out the yokes, upending them and pumping in to a collection vessel.
many thanks for that ...i presume you just put the desired amount of oil in each leg at the open end(nut removed) and just tighten things back up is it
