September 22, 20197 yr Fitted a new clutch but it seems to slip when a need the power like when time trying to climb a rock or up a hill any ideas please I've checked the obvious making sure theres play in the clutch lever
September 22, 20197 yr If it's a gasgas pro the clutch pack needs to 9.75 mm thick minimum otherwise it will slip.Are you sure the plates are installed in the right order.Theres information on utube on these clutches,when they're right they're very good
