Manual
Anyone have any kind of downloaded manual or torque guide for a 2007 beta evo  ?
Cheers Jamie
Go onto the lampkins beta website. Look in the info section and you can get pdf manual downloads there. If not try the beta main website or beta USA.
Are you sure it’s an Evo? I thought they came later. I had an 07 rev 3. I wonder if you also have a rev 3?
Edited by pindie
Cheers both,  my mistake its a rev3 not evo..
Also found the following on this site
had a file with these in, think i may have copied it from a previous post
Tightening torque Rev3:
Shock absorber-Swingarm 45Nm
Shock absorber-Frame 45Nm
Connecting frame rod-frame 23 Nm
Cylinder-Crankcase 20-23 Nm
Primary drive gear 120 Nm
Handlebar 25 Nm
Engine-frame 50 Nm
Swingarm bolt 90 Nm
Front wheel axle 65 Nm
Rear wheel axle 65 Nm
Steering stern bracket 25 Nm
Rear fender bracket 10-15 Nm
Front brake pad 20-23 Nm
Rear brake pad 20-23 Nm
Engine Head-Cylinder nuts 15-16 Nm
Front axle fixing nuts 10 Nm
Flywheel 140 Nm
