Mark Wall Posted May 10, 2020 Report Share Posted May 10, 2020 Hi I need a LHS fork slider to get my Guanaco out on the sections, the Left Hand Side for bottom (slider) has cracked at the spindle clamp, anyone got a spare or fork leg or forks for sale please. Thanks  Mark  Quote Link to comment Share on other sites More sharing options...
kurtas Posted May 10, 2020 Report Share Posted May 10, 2020 You could probably have a go at a weld repair as it appears to be cracked far enough around the spindle that it is not completely needed for taking the load and its function would be more about retaining the spindle. 2 Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted May 11, 2020 Report Share Posted May 11, 2020 Several of these were weld repaired back in the day, I think the gap where the pinch bolt goes was too wide on the original model, leading to the lug cracking. A thin washer in the gap pre-empted the problem. Quote Link to comment Share on other sites More sharing options...
Mark Wall Posted May 11, 2020 Author Report Share Posted May 11, 2020 Thanks for the good idea, I shall make a spacer as you advise, Many thanks  Mark Quote Link to comment Share on other sites More sharing options...
