bulfrankx5 Posted October 9, 2020 Share Posted October 9, 2020 hi is it essential to wire clutch nuts and how tight should nuts be handbook says nuts should be fully tightened then backed off 3 full turns my lobito 175 has the smoothest and lightest clutch ive ever come across daft question what sort of wire......some can be brittle it needs ductility??? maybe copper ...too soft??? suggestions please Quote Link to comment Share on other sites More sharing options...
feetupfun Posted October 9, 2020 Share Posted October 9, 2020 Set the nuts so: The pressure plate moves out parallel. There is just enough drive to kick start the motor without the clutch slipping. You can set this with the clutch cover off but the plates need to be well lubed. Stainless steel lock wire. Copper wire work hardens. Of course it would go fine for a while without wiring but do you need the stress in your life of wondering if they were going to move? 1 Quote Link to comment Share on other sites More sharing options...
bulfrankx5 Posted October 9, 2020 Author Share Posted October 9, 2020 cheers for that and thanks to woody too Quote Link to comment Share on other sites More sharing options...
carl ekblom Posted October 9, 2020 Share Posted October 9, 2020 (edited) I use all metal lock nuts. After two years no problem at all. I think nylock may deteriorate in transmission oil and heat Edited October 10, 2020 by carl ekblom Quote Link to comment Share on other sites More sharing options...
bulfrankx5 Posted October 9, 2020 Author Share Posted October 9, 2020 cheers for that Quote Link to comment Share on other sites More sharing options...
