October 10, 20206 yr my recently bought 348 was missing the front brake torque arm.No problem I thought, 2 on ebay both saying for 348 both 5155.050 .Got one and it does not fit! seems to be too long. Whats happened.Could be getting the grinder and welder out.
October 10, 20206 yr As per feetupfun, give us a pic if you can, or at least the dimensions. Cyclesavant in the US has a couple, stating 23.5cm end to end, I'm guessing 22cm hole to hole. https://www.ebay.com/itm/Montesa-NOS-51M-Cota-348-349-Alloy-Brake-Stay-p-n-5150-050-51-50-050-1/301583685771?epid=716924065&hash=item4637c9d88b:g:nvgAAOSwNSxVHvvP Edited October 10, 20206 yr by fourex link didn't work at first.
October 10, 20206 yr Author hi,thanks for the replys.that one on ebay is the same one as i had from Motoclassic in uk. if i hold it up to the forks and line the holes up the brake pivot is in the way.If it was a bit shorter I think it would work.I could do with knowing what the hole to hole gap should be. the part number is 7355.48 on one manual Ive discovered
October 10, 20206 yr There is normally only a tiny clearance between the torque link and the pivot arm
October 10, 20206 yr I just make mine from alloy strip from the local hardware store. You can easily make one up and make the hole at the top end extended so the arm will effectively lengthen or shorten so more adjustment can be had as the brake shoes wear. Edited October 10, 20206 yr by cleanorbust
October 11, 20206 yr 20 hours ago, chudder said: hi,thanks for the replys.that one on ebay is the same one as i had from Motoclassic in uk. if i hold it up to the forks and line the holes up the brake pivot is in the way.If it was a bit shorter I think it would work.I could do with knowing what the hole to hole gap should be. the part number is 7355.48 on one manual Ive discovered Part numbers starting with '73' are Cappra VR/VB I'm led to believe.
October 11, 20206 yr 22 hours ago, chudder said: I could do with knowing what the hole to hole gap should be. My 348 is 195 mm centres
