November 6, 20206 yr Hi All, I've recently bought some tech forks for my Beta Evo 2020, with S3 yolks. I've managed to installed them fine but can't find any instructions as to the right height for the stanchions in the yolks. There is a ring at the top of each tube, I assume this needs to align with the top of the yolk? Does anyone know? Also, for anyone interested in doing the same upgrade, you need a 9mm thick M20 spacer for the axel (brake caliper side) and x2 5mm thick (ish) spacers for the brake caliper bolts. I made the wheel spacer by buying a 4rt spacer and cutting it down. The beta evo also needs an O ring under the bottom headstock bearing.
November 7, 20206 yr Author Thanks Casco. I managed to find a thread that said the lower they are the less the front wheel will wash out, the higher the mote stable it will be.
