Intotrials Posted November 10, 2020 Share Posted November 10, 2020 Hi folks, I've recently bought a 300rr and still getting used to the bike. It has come with a 41 tooth rear sprocket and a 10 tooth front, which I believe is standard? On my first outing I found that the bike rides really nice running in first gear but is a bit quick in second. My spare rear wheel has a 42 tooth sprocket from my previous bike (300 gas gas) I ran this and didn't find a lot of difference, but have since noticed that second is now only very slightly more manageable. My friend is running a 43 tooth rear sprocket and uses second much more, he is preferring this setup, I rode his bike and I'm not convinced. What do you folks run and why do you prefer your setup? Thanks Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted November 11, 2020 Share Posted November 11, 2020 (edited) I run stock on my 300RR and use the clutch more, however I have tried a 42, 43 and 44 rear and found that after a bit of adjustment time I liked the 43 better than the 42 or 44 over all. If I was going to change the rear and only had a 42 or 44 to pick from I would go 44 so that 2nd was more usable and I had an extra slow 1st for really tight section work. In the end I doubt I will ever use anything but stock gearing but every once in a bit I consider running a 43 or 44 for a year to see how things would end up working out... who knows maybe I will at some point... good luck. Edited November 11, 2020 by jonnyc21 1 Quote Link to comment Share on other sites More sharing options...
