Tiger cub alloy centre fixed fuel tank
Can someone advise how to mount fuel tank to fecked purchased bar, can’t seem to find any fixing kit ?
Usually a bolt, welded to the frame, rough!y vertically. The length and position determined by the tank. A rubber bung is sandwiched between two largeish washers, and when compressed holds the tank. Usually some pipe insulation under the tank keeps everything snug.
Edited by b40rt
Make a saddle possibly by cutting a length of steel tubing in half longitudinally then weld a bolt vertically to the outside of the tube thread pointing upwards the correct length to secure the tank as on the above post, secure the saddle to the frame top tube using two Jubilee clips.
Thanks lads, I have the aftermarket bar with the nut welded in to accept a bolt just thought it might need more than this to stop it swinging about !
