keychange Posted March 29, 2021 Report Share Posted March 29, 2021 Hi Need new steering head bearings for my TLR200 are they standard ie: can you tell me the specs or do I need to buy them as a TLR set. Cheers Quote Link to comment Share on other sites More sharing options...
technowaldo Posted March 29, 2021 Report Share Posted March 29, 2021 Whip them out and get the numbers off them and order a set from your supplier Quote Link to comment Share on other sites More sharing options...
not ron Posted March 29, 2021 Report Share Posted March 29, 2021 This is complicated, assuming you mean taper rolling bearings, if not then I cannot help. Â The upper bearing is 48.5 x 26 x 15, the lower is 48.5 x 27 x 17. or some lower bearings are 15 deep with a reduced diameter boss on the lower side, note the internal diameters are different upper to lower. Â , Â 1 Quote Link to comment Share on other sites More sharing options...
keychange Posted March 31, 2021 Author Report Share Posted March 31, 2021 The bearings fitted are just loose balls. Â So I want to upgrade ....spine is 26mm top and 27mm bottom. 1 Quote Link to comment Share on other sites More sharing options...
not ron Posted March 31, 2021 Report Share Posted March 31, 2021 The upgrade most people do is the taper roller bearings as I defined 1 Quote Link to comment Share on other sites More sharing options...
keychange Posted March 31, 2021 Author Report Share Posted March 31, 2021 Yep, got it Not Ron....ordered today. Thanks 🤪 1 Quote Link to comment Share on other sites More sharing options...
